I just installed an o/r x-pipe and my headswapped 96GT sounds awful. The car already had 2 chamber flowmasters on it but with the o/r x they sound like glass packs at around 2300 rpm. Anyone have any suggestions about which mufflers would sound the best? I'm thinking either dynomax or 3 chamber flowmasters but have not heard either one with my combo.
Discussion Starter · #2 ·
should I have gotten an o/r h pipe instead of the x?
dynomanx ultra-flo or any type straight muffler will work with the x pipe. i had the same setup you have now and it sounded like a truck when i shfted.
Discussion Starter · #4 ·
thanks, are you running the dynomaxes on your car? I don't mind it a little loud as long as it sounds good.
Wouldn't it be nice if there was a place where you could listen to an exhaust setup before you bought it? Oh wait, there is such a place! Check my sig!
yes i am running the dynomax now the flow were only on a couple of weeks before i had them cut out and welded in the dynomax.
