So it’s getting time for exhaust for my 65 fastback with
2 valve push rod motor
Vortech V3 si
Cam
Intake .572 exhaust .566
272 281
On 115* lobe separation
Looking for something more on the quiet side will more than likely be running 2 1/2 inch mandrel bent Tig welded with H pipe
Like to have something on the quieter side I prefer deeper smoother tones.
Give me some ideas please!
I’m considering magnaflow
I've read about quite a few guys running OEM 2015+ Muffers on their cars to quiet them down and still retain a nice growl. Been searching for sound clips but haven't found any yet.
Same issue here...i want to actually quiet my car down, but not lose (much) power.
I’m going to try the alt with out tensioner.
It has decent wrap so might work
If it does slip I’ll just pretend I intended it too. Kind of like a clutch fan 🙂
I think what the second poster meant was actual stock 2015+ mufflers with different hangers welded on work well to quiet down a sbf.
They certainly flow well enough for 400+ hp.
FWIW on a foxbody it seems those are too big to fit under the car, the body is too tall from what I saw
On another note after spending some time browsing the Walker catalog I found these two options, PN 21762 and PN 21548, they both fit size wise, are 2.5" offset and like OE one is longer than the other. What I don't know is how they sound and if the two are the same inside. I am going to try them when I redo my system.
And lastly I honestly wonder if a 2.25" is going to cost any noticeable power in a street car application.
The more sound clips I listen to the more I’m liking Dynomax super turbos
They have interesting design that uses reflective curves along with glass pack design.
The magnaflows that i initially Liked seem to break up and crumble like a glass pack at higher rpm.
And these seem to hold steady sound.
I’m actually considering going with 3” Because future upgrades to stronger shortblock I’ll want more power than 2.5” likes.
I’m really interested in the walker oem mufflers and I can see how using different size mufflers on dual system could help with drone
I went with Dynamax UltroFlo's on mine b/c I've had good luck with them being really quiet but they are still a straight through design so they flow good.
I have the Dynomax VT. It is a straight through design but incorporates a spring loaded valve that stays mostly closed under light loads. No drone whatsoever and the noise level is not bad just driving around. Under load though the valve opens up for unrestricted flow. I dont see them on Dynomax's website now.
On my 92GT, I curently have Tokico Illuminas with FMS C rate springs..
I don`t like the rake forward.
I'm running MM LCA's and FMS HD UCA's
I want the car to sit straight and even, as i have seen many others with this stance.
«the car is for Street use only, not racing.
I was looking at H&R...
I'm doing a 2V swap in my 89 Coupe. I bought the Stifflers crossmember for the T45/3650 and I'm going with an 03 Cobra IRS. Can I swap the 3650 yoke and and the IRS rear flange to a fox driveshaft and , or do I have to have something custom made?
Any help is appreciated.
I'm trying to get some ideas for my 89 coupe. I'm going to reupholster a set of Corbeaus and possibly the door panels. Does anyone here have pictures of their redone fox interiors?
Ok I have a 1989 Ford ranger that has a 1993 Ford thunderbird 5.0L ho v8 engine in it which has 19lb injectors a cobra jet cam and gt40p heads and max flow headers with true dual exhaust with a 1996 Ford f150 5 speed manual transmission. As for the computer I'm using a 1993 mustang gt a9l with...
Anyone have the LMR 10-Holes?
I love the stock look and see they make a 15x9 and 15x7. They sell the 15x9 with 275/50R15 MT ET Street SS as a package.
I would like to know how the fit and finish is. Any pics other than the LMR red coupe?
