Hello,
I'm helping my friend with his MSpnp2 installation. He has a 1991 5.0 AOD and is upgrading to a 351W engine. Combo is as follows:
We will be using some of the wires coming from the options plug:
I'm also attaching a base tune file that I put together to reflect all the information above. Could someone please take a look at it and comment on any changes that I need to make?
* I had to change the file extension in order to attach it. If you just delete the .pdf you should be able to open it. *
- 351W roller block
- AFR 185 heads
- Not sure on compression, but built for naturally aspirated
- 1.6 roller rockers
- Stock Ford ignition and TFI mounted on a Ford distributor
- TFS intake manifold
- 42 Lb/hr green top injectors (eBay, so we'll see how these work out)
- BBK in fender CAI
- 1994 Cougar 3.8L MAF
- 70mm BBK TB
- Custom cam, high 220's duration at 0.050" and mid .550" lift both intake and exhaust, low 110's LSA
- Single electric fan
- 1 5/8" long tubes with O/R X-pipe into Spintech mufflers
- Beefed up AOD, 2600ish stall
- 4.10 gears
- Wire 05 - Chassis ground. Should this wire be grounded to where the factory A9P was grounded?
- Wire 13 - Launch control input. I'm using this for my A/C idle up input. I moved jumper J3 in the MS and it will be tied into pin 10 of the EEC harness.
- Wire 19 - MAF sensor signal. I installed a jumper inside the MS from the external MAP pin to the ADC1 pin. Option wire 19 will be connected to pin 50 of the EEC harness.
- Wire 21 - Oxygen sensor input. My friend had an Autometer WBO2, so the blue + analog output wire from the WB will go here. I did change jumper J6 in the MS to reflect this.
- Wire 22 - Signal Ground. Here I'll connect the - black analog output wire from the WB and the MAF pin 9 wire from the EEC connector.
- Wire 24 - Output 1 relay control. This wire I'm going to connect to the fan relay 85 terminal, the one that would be on the other side of the relay coil 86 that is getting a 12V switched +. We are also going to use a second relay to turn on the fan with a signal from the A/C clutch from pin 10 of the EEC connector.
- Wire 25 - Output 2 relay control. We are going to use this one for the A/C WOT cutoff relay and connect it to pin 54 of the EEC connector.
