21 - 26 of 26 Posts
Any update on performance with the Volvo controller? Requires two outputs from ECU to run hi/lo?
Haven't messed with it yet, still on my bench.
It's 3 wires in. Power, ground, and a single wire back to the ECU for control using PWM.
2 wires out to the fan. I'm using a V6 Sn95 fan, which is Hi only.
Only thing really keeping me from testing it is that I'd need to pull a battery out from one of my vehicles to bench test
ought to buy a 1000+ watt server power supply for bench testing electronics. This is what I use and works pretty darn well.
i know. It would make things very easy. I need to search for one to buy
Hi....It's what I used before the PWM fan controller. 1st one was Variflow, then the DCC. Same inventor, different design & company. I still have the relays & one of the same model without the clamping diode across the relay's coil.
pcba prototype
None yet. In the midst of my project as we speak. Engine being rebuilt, chassis next, and hopefully wiring up the MS3x and fan controller this summer.
How is the PIMPx accomplishing the fan control?
I just got an MS3 Gold and am trying to figure out what I need to do to get the fans to work.
I pulled this from DIYAUTOTUNE:
"If you have an MS2, you can use the two stepper IAC outputs to drive the relays – just wire the two IAC1 wires across the coil of the low speed fan relay, and the IAC2 wires across the coil of the high speed fan relay."
I assume that this would work on the MS3?
21 - 26 of 26 Posts
