I have been helping a friend on a 363 aluminum heads TF R intake and a hyd roller comp cams cam kit. It is as big of a street cam one could possibly use and expect drivability. Spec 578 lift 245°of [email protected] 0.50 lobe separation is 110° i talked him into purchasing MS 2 on the pretence that i would install it and tune it good enough to take it to a dyno.ive spent a lot of time on it and trying to make sure this firing orfer issue is not a take away power part. I spec a ford letter to cam designed for EfI and as in other things he chose a different cam.
im concerned about his builder spec a cam with the old firing order to pre EFI. My thoughts are ford changed the firing order for a reason and loosing power is just not going to cut it. Leaving fuel setting on a intake valve because it was injected out of time to early or to late is not optimal. Please correct me if my reasoning is wrong. I do not wish to chase in my tail anymore than needed learning curve for the old old school guy is testing my patience.
Next question with a 8 cylinder engine setting in MS2 and a single wide ban 02 sensor does the ms 2 figure the AFR with the asumpttion my other 4 cylinders are the same AFR . (in other words left bank x2) = total engine AFR) or do i need two 02 sensors. Thanks in advanced for the help . Fyi im using the DIY PNP MS2
