1 - 14 of 14 Posts
I'm curious if anyone has used the Racecraft or Team Z mounting brackets in a SN. I'm 5'10" tall and shrinking. I need to at least see over the hood. It appears that these brackets mount the seats pretty low.
Pics? Experience?
I am just a CH shy of 6' and used the Racecraft brackets with my Kirkey seats. I have no issues seeing over the hood There is a lot of adjustment built into the brackets. Just get the height right before you drill holes into the seats to mount. I used blocks of wood to get the position right and had my brother help mark the seats before drilling and mounting.
Mine are installed in a new edge but it shouldn't be much different in a SN95.
1059147
Thank you! That looks great. Who's cage did you use? How's headroom with a helmet on?
I went with a Wolfe Race Craft chromoly cage and I still have a few inches headroom with my helmet on.
Thanks for the info. Brackets ordered.
  • Like
Reactions: quikbluewagon
One more question. How did you mount the crotch straps?
Are you trying to meet NHRA rules? If so, the crotch strap mount must be behind your crotch. I went with a 1/2" grade 8 bolt with a big grade 8 flat washer. This bolt goes through the floor pan and through the sub-frame connector cross support for the rear of the drivers seat mount. This way the mount is effectively tied into the sub-frame connector.
Are you using the MM subframe connectors? The cross bar that attaches to rear seat bolts doesn't have a flat edge for the washer to seat.
I have the Kenny Brown sub-frame connectors. I am sure that you can make accommodations to get it mounted correctly.
Use or make something like this:
1059253
Discussion Starter #14
Thanks guys! Those are great ideas.
1 - 14 of 14 Posts
