This has ended up costing a lot more then I had planned, but what can you do? Too late to worry about it now. Could have saved some money by assembling it myself, but it's a "drop in motor" now and that's kind of nice. Some of the parts listed here were needed because they were destroyed when the 302 went KABOOM.
Breakdown of invoice:
Fox Lake 347 Stroker shortblock with 10.25:1 Probe Oil Control Pistons and steel crank:
$2250.00
Upgrade to Eagle H-Beam rods:
$200.00
TFS Stage 2 Cam:
$139.00
Repair and mill damaged heads (new valves/guides/springs/milling)
$530.00
New timing Cover:
$69.00
Custom Length Pushrods:
$89.00
Port-Match lower intake:
$125.00
SFI Balancer:
$269.00
Timing Chain Set:
$89.00
Blueprinted Oil Pump:
$65.00
ARP Head Bolts:
$43.00
ARP Balancer Bolt:
$25.00
Assemble longblock, degree cam, set valves, gasket kit, install balancer and timing cover:
$462.00
Shipping:
$205.00
Total lift with 1.7 rockers will be 578/590
I guess I'll do some sort of writeup if anyone is interested, when the motor gets here, as well as a writeup on impressions/results.
Thanks for reading.
$2250.00
$200.00
TFS Stage 2 Cam:
$139.00
$530.00
New timing Cover:
$69.00
$89.00
$125.00
SFI Balancer:
$269.00
Timing Chain Set:
$89.00
$65.00
ARP Head Bolts:
$43.00
ARP Balancer Bolt:
$25.00
$462.00
Shipping:
$205.00
Thanks for reading.
