1 - 9 of 9 Posts
I am putting together a notch for track only duty. I am looking to run 10's. I have an R block and plan on having a 347 built. What manifold/carb combo would get me into the 10 sec range. Also would the holley blue fuel pumps be enough or should I go bigger on the fuel system. It has a 5 gal fuel cell installed. Thanks..
92CarbedNotch said:
Vic Jr intake, speed demon 750cfm will take you there.
I would go with the holley black pump.
Thanks, would the black be able to handle a power adder? My coup is also a "92". I have the suspension and cage going in now and want to tackle the fuel system next.
No, I would not push my luck on the fuel pump. You could do a dual set-up, 1 for motor/1 for nitrous. You should be ok for this set up to around 700hp. I would run 2 blacks, or black on motor/blue on nitrous.
Good Luck, Greg(XSR)
Yes that will work, but most of the good(big) pumps are expensive. Just tring to help you out money wise, go with atleast 240gph.
Hope I helped out, Greg(XSR)
So should I go with a holley black 140 gph for motor and maybe a Holley blue at 110 gph for the nitrous? The Holley 250 gph pump is over $300 like the Aeromotive. I guess there is no cheap way.
i ran 2 pumps..both are comming out the Downs Ford intanke pickup tubes..ones it like 5/8" and the return is 3/8"..i used them both for pickups..works fine
1 - 9 of 9 Posts
