Well I was curious what tire size as far as width makes a 17x9 look the best, like makes the rim look bigger and more appealing..I find the 275 to make the rim look smaller, the 255 to make it look the best, i have a 95 stang what would be the most appealing tire size for my rim so tha the rim looks the most attrative at??
Blake
What style wheel do you have? I ask that because appearance varries with the size and thickness of the amount of visible metal on the wheel . Smaller "5 stars" will look different that thicker ones, just like wearing verticle stripes make someone look taller and slimmer. I all works together to create the image perceived by the eye. Not trying to be an A.Hole, this would just help me get a better idea.
B.S.
255/45/17s have a larger overall diameter than 245/45/17 and 275/40/17 causing your car to lean back slightly. If you ask me it's rather unsightly to have a taller tire in the front than the back. It's not a front wheel drive.
I vote for 275/40/17
