Thought I would share my experience for future reference for others here on the Corral. If you purchase Moser axles........BE PREPARED TO GRIND!!!! I had to grind about .030" off the end of each axle today to get them installed. I measured the stock axles versus the Moser's and there was approximately .030" difference.........and it was a consistant difference between both axles. Other than that, the swap was pretty simple. Hope this helps somebody in the future!!
Hmmmm....I have heard that before. But, when I snapped an axle on a launch... I had the rear re-done with an eaton posi and 31 spline mosers... and they fit like a charm! I guess it's the luck of the draw???
Yea, those Mosers are a tad long. Cannot push all the way in to install the C-clip. Helped a friend do this before. Didn't you just hate grinding on the new axle. Not a good feeling. Should have sent them back, but having to do it 2 times or some grinding, guess which won. Glad you got them in with no other problems.
Discussion Starter · #4 ·
Yeah........I hate having to modify any brand new parts that are supposed to be a direct replacement parts!! It wasn't hard to grind them........but it was something that Moser could have prevented at their factory. I know one thing........they are definitely a lot harder than my stock axles!!! :D
snakebite,
is the hub deep enough so the wheel rest on the hub and not just the studs? that's another measurement those a**holes messed up on my axles. now the weight of the back of the car is resting just on the wheel studs, not the hub like it supossed to.
Discussion Starter · #6 ·
Twofast,
I did not notice any other fitment problems. Wheels/brake rotors fit the new axles, just like the old ones. I guess I'm not exactly sure what problem you are describing. Can you elaborate?? It might be something that I need to check......that I did not notice during the install. Thanks, Wayne.
