1 - 8 of 8 Posts
Okay, here's the deal.
A good friend of mine will be building a car this year. The car will be more of a street brawler, weekend viper killer.
At this point, he's not sure if it'll be an auto, or five speed.
I think i've got him convinced on going 408+ n/a, Dart block based, solid roller, AFR205's or 225's or some TFS R's or Vic Jr's, probaby 10:1 compression for future nitrous use, 1 3/4" longtubes, 3" exhaust, 4.10's, tubular front suspension, custom cam, and unclear on intake. He's not looking for more than 6500rpm fwiw. Anyone out there running a carb setup like this? What type of fuel system would be needed if going efi? Would a 255 intank, 42's, stock rails and an inline pump handle that type of power?
Does anyone out there have a similar combo? What kind of power numbers can we expect?
Any ideas or comments on intake or head choice would be appreciated.
Thanks!
Mine's a solid roller equipped 408 with 10.3:1 compression. AFR 205's out of the box along with a box stock Super Victor carb intake with a big Holley 1000cfm. Headers are larger 2" primaries (overkill at this point) though.
I'm pleased with it. With a loose convertor and C4 it still put down 465hp/481tq at the wheels. Easy 550hp at the crank. In my 3350lb coupe mid 10's all day. I plan to get the convertor tightened in the spring and that should gain a tenth or 2 and a few MPH. Then get the car down to a lighter 3100 race weight.
Should do bottom 10's on motor, then the nitrous will get introduced and get me booted off the track.
I can't complain.
I have 11.39:1 compression in my solid roller 408(A351 block) with TFS R heads (Stage II from T.E.A.) and a modified Holley 850DP Annular ontop of a Super Victor 351W intake. It also has 2" primary headers (3 1/2" collectors) and is totally streetable, but I would prefer smaller headers, as these aren't really needed. I add Octane 108 to the fuel just to be safe until I get it tuned properly, which isn't happening now due to the engine swap in progress.
My cam is a custom design, but Comp sells it to Keith Craft, if you're interested in what they use. Keith Craft Racing Engines I like it and it's designed to reach peak power at about 5900 (for street use). It's also a nitrous cam.
If you go injected and all motor, the 42's should be fine, but the stock rails probably won't. I decided on a BG400 and a step down box, since I have nitrous too, but a BG280 would probably work fine. A 255 should work well in the setup you have in mind, with EFI, of course.
Keeping a 5 speed sounds great, but it will prove very difficult to drive well. Shifting comes fast and often with this power and torque. I tried a C4, but it died quickly, so I'm having a C6 built and I'm completely sure it won't slow me down, or break. 408's just make so much torque, it's not a concern to me.
TC89LX, What block are you using? I started my 395ci buildup (393 .040 over) and I'm now wondering if the block can handle it. Mines a '74 vintage.
AnuttrFordguy, how well was your c4 set up? I was going to go with a PA super comp but now I'm questioning that too. I figured it would be good enough for low to mid nines at least, correct me if I'm wrong.
A '74 block should hold pretty well. I just wanted to go with all new stuff.
My C4 was an Art Carr and they told me it was a "full roller" and it was a reverse manual valve body, with a T-brake. SFI approved bell housing and all. I believed them when they told me it would handle street driving, because I STRONGLY questioned that before ordering and was always re-assured. Only problem, they were WRONG! :rolleyes: I had it in the car just a couple weeks and it lasted all of 7 passes, all simply "shake downs." Then I decided to use ET Streets at 14psi .... Well, BA BOOM! :barf: and that was the end of that. Wheels lifted, wheels dropped (thought it was spinning)... Slammed 2nd, got nothin' but rpm.... TOASTY CRITTER BELOW!:eek: They never did tell me what was broken, but I can tell you NO forward gears worked after that day! I should pick up my locally built C6 Monday. The only other route was a "slip-n-slide" and I don't want a 2 speed. I will say though, I would really like to have overdrive. Just can't really afford a LennTech. I know other guys using C4's but they aren't street/daily driven cars like mine. PA is about the best there is though, when it comes to C4's.
EDIT: BTW, I will likely be selling my PA SFI 29.1 (or whatever) flexplate soon. If you're going with a PA C4 and want one with LOW mileage, price there's and make me an offer. I'll know in a few days whether or not I'm selling it. ;)
Yeah, I've already weighed my options on the overdrive and decided it's time to buy a trailor for going to the races. Mine isn't daily driven now anyway, I just take it out for a spin to the grocerie store every once in a while when the weather is nice. It's a '95 and only has 34K. It honestly gets driven about 2k a year if that.
Are you considering selling the flexplate or the whole setup minus tranny? More info. PM me if you'd like.
Mine's stuffed into a vintage girdled 1988 F150 block LOL! Fingers crossed at this point but eventually I'll be moving over to a big bore (4.125") DART block for soem bigger cubes.
I run a Dynamic C4 behind mine. Same tranny that was behind my blown 302. This summer will be 2 years on it with plenty of abuse, although I am cracking it open to add a transbrake. Good stuff and hasn't failed me yet either on the street or the strip.
I've simply returned everything else, since it was "defective" by design quality... So all I have left is the flexplate itself, which was purchased seperately. Since it wasn't defective, or bought with the rest of the parts, I couldn't return it. I may still have need for it, but I should know by tomorrow.
1 - 8 of 8 Posts
