91, 5.0 with a 2019-2020 PRO-M EFI system
calibration file is v8.0
Hi ,
I am to the point in the first start up instructions where I am setting base timing by cranking the engine with the injectors disabled
The instructions say clearly with a picture , to disable the injectors by going to the calibration file under:
-Fuel
The calibration field crank_fuel_mode is missing. Any idea how to make the field show up to disable the injectors ?
What am I not doing first?
thanks for any help
Geoff
Hi ,
-Fuel
Problem:Cranking
>crank_fuel_mode
>> then change the setting in crank_fuel_mode , from lambda to disable
thanks for any help
Geoff
