Hey Chris (would like to pick your brain a sec)
Could you elaborate a bit on testing the coil packs. I'm just curious sine once it gets warmer I start back up on tuning the car myself (Tweecer). I want to ensure my ignition and fuel systems are up to par before I do (I have made some minor changes already to timing and the MAF transfer function). I plan to replace the fuel filter and with over 40k miles on the coil packs I want to be sure they are working OK. In addition the new FRPP wire I have are of questionable qulity and although they are newer (<5k miles) I want to ensure they are firing OK.
Do I start the car, pull the spark wire from the coil pack, and then use the ohm meter to test the coil pack inidvidual port and then the wire? If so, I see you indicated I should see between 12-13k for the coil pack port, how about the spark wire (is that the 2k you menthioned?) Thanks Chris (cool name btw)
Could Jbes problem be spark blowout? What kind of plugs are you using jbes, what gap?
