1 - 8 of 8 Posts
Completed a black interior conversion and have some qualy parts sitting around.
Black Passenger side A/C vent. The vent was missing the middle fin. I had a spare complete vent laying around so I removed and painted the fin OEM landau black. The vent is tight and functional. Also went over the white trim. And replaced the shut off flap Looks top notch. -50
Black driver side vent (clean and functional touched up white trim) -50
Gray dash pad (soft and clean) -35
Gray center vents (clean and functional) -25
Gray kick panels -25
Gray door sill plates -25
Gray passenger seat (very clean) -150
Gray center console arm rest (latches perfectly) -75
Gray knee panel -25
Gray notch rear seatbelts (decent) -50
I also have the gray dashboard and dashboard frame. The dashboard was drilled by the emblem where the previous owner thought it?d be cool to install a Cobra snake. Also the housing for the climate control is cracked at the lower portion. It?s fixable. I?ll take 50 bucks for the dash and frame. I can repair the damaged areas and repaint the dashboard black as well but that would be at the buyers expense.
Buyer is responsible for PayPal fees and shipping.
PM for pix.
Moderator
Fox? sn95? s197?
Will this stuff work on a 1985 Mustang GT?
Do you have any pics of the gray dash pad and knee bolster?
is the knee bolster the part that goes under the steering wheel down below?
It WILL Fit the 1985.
A 1985 is also a Fox Body.
is the knee bolster the part that goes under the steering wheel down below? YES
Just here to help on this one...
1 - 8 of 8 Posts
