How do you remove the mirrors on a vert? I'm painting them Thurs!
Thanks!
It's fairly easy,
Take the door panels off, there will be 2-3 nuts holding each mirror on. I would disconnect the wires (single plug) and then unscrew the nuts.
Clayton
Da*n, I was hoping I wouldn't have to remove the door panels..... I always had rattle problems after I did that on my Explorer......
Thanks for the help!
Do you have mach460? I'm almost positive if you have the tweeter pods that all you have to do is take a flatheat screwdriver, pry the pod covers off (CAREFULLY), and 1 torx screw takes out the pod. Then the mirror bolts are right behind it.
Discussion Starter · #5 ·
No, I don't, but it sure looks like the little covers would just pop off....... Hmmm....
