where do i connect the line thanks
The easiest way is ditch the factory electrical sender and hook it up right there. You should've gotten the adapter/connector with you gauge. Piece of cake!
I put a T in so i could run the factory sender and run the mechanical line.
I hate having dead gauges
Mines hooked up like LilBlackCoupe said... i couldnt get mine out so i had to bust it off and then use a socket on it... i think it was 1" or like 1 1/16"
Don't use the white vinyl/plastic line they included with the guage!!
I had one of those lines break on me once. If that happens, you'd be surprised how quick your engine can pump itself out of oil. Luckily for me, it sprayed right on the header so I could smell it and only lost a quart or so.
Go and buy copper tubing from a place that sells fittings and that sort of thing. Its easy to bend and route into position and won't break open like the plastic crap can.
