I'm in the "process" of connecting a mechanical fuel pressure gauge inside the car. PITA!!! Saw in the autometer catalog-mechanical/isolator= 49.99 Got PN4309. NO LINES!! Called Summit, said I needed PN5282 to mount inside of car (gauge isolator). Got that. Found out it has a 4AN fitting on the fuel side, need a 1/16 pipe fitting to go into the fuel rail. No hi-po shops here have the parts. JBA had the adapter for 1/16 to 1/8th, but that was it. Searched just about every other speed shop, no luck with the other parts needed. Finally went to a hydraulic hose shop=everything needed. Would have been nice for some literature in the catalog. For Mustang, get PNxxxx, xxxx, xxxx and xxxx ect. Would have been nice for the monkey working the phones at Summit to know a little more than his a$$ from a hole in the ground.
Sorry, just venting some frustration.
Will post pics with complete install write up probably tomorrow IF it finally works, barring any MORE complications.
So far total on this install
guage 49.99
isolator 99.99
misc adapters 20.00
Should have just gone with electrical!!!!!!!!, but stuck now with the mechanical!!!
:livid: :curses: :crying: :blam:
