1 - 1 of 1 Posts
less than 3 months old this was a new item from mcloed to adapt a t-56 from an lt1 camaro to any 5.0 block.it required major trans modification from them but i redesigned it to only need a syeel plate that bolts to existing trans bolts so absolutley no trans moda are needed.It works perfectly withj the stock cable clutch and will come with a spec stage 4 clutch to work with the trans imput shaft.many hours of labor to reengineer this part,bellhousing sells from mcloed for over 300,and the clutch sells for over 400 will sell for 600 plus shipping e-mail or call 815-719-0756
1 - 1 of 1 Posts
