I have the track heat intake since I blew out my plastic PI intake. I ran a 75 shot all last season with no issues and was trying to get some input on how big I can go this season. Basic bolt ons and a solid motor. I was thinking 150 but maybe I can go bigger. Any thoughts would be appreciated. Also what RPM range should I use on my rpm activated switch. It's at 3000-6500 now.
99 GT SCT BAMA Tuner, CAI, UD Pullies, 75mm TB, Trick Flow track heat intake,Wet NO2 kit, Long tubes, O/R H pipe, flow master catback, 4.10's w/ carbon fiber rear end rebuild kit, AT with shift kit, 335's out back.
150 is the largest I personally would go, unless it was a direct port setup. Or get an edelbrock and fuel puddling will be the least of your worries with a 4150 plate.
^^ that
still a 150 with that intake, even if you had a built motor.
Need a dp kit or something designed to carry fuel, like an Eddy.
3-6500 is fine
