I'm planning on having my original block rebuilt as a N/A monster and was wondering what most folks here think would be the MAX compression ratio I could get away with on the street running straight up 93 octane.(no octane booster additives) I figured 10.5:1 @ a minimum.
11.5:1, 12:1, possible??? Thanks...
My guess is 11:1-11.2:1 Maybe Duane V will chime in here as I think his car runs 11:1 or higher and it is N/A.
What cams will you be running.. That would affect my answer..Al
Discussion Starter · #4 ·
Don't have the specs yet but they will be custom stock regrinds. Should be making close to 400rwhp. I'd like to err on the conservative side if need be.
If I may ask, which aspect of the cams are the most influencial(duration, lift or LCA?) on compression?
You will need a very effective quench zone. With a custom piston and the right combustion chamber shape you should be able to easily run 11+.
It's a lot of work for the power you will get.
Then again it's not my car.
Corral Charter Member
One of these days, I'd like to have a 4.6-based 400-ish RWHP n/a combo for my 99 Cobra. Gotta be streetable, and has to be 4.6 based (or perhaps the mod 5.0, if it becomes readily available).
