What am I doing wrong? I can't put pins into the wiring harness or take pins out of it... any ideas? I pulled on the front red thing, but it didn't come out too far... I have a picture.. Any ideas?
That red piece has to come out completely. It holds the clips that hold the pins in place. It should come out. Use a little screwdriver on the end, edge facing in the pic and get in between the grey and the red pieces and pop it up. Do it one side, then the other if this doesn't work.
Red thing definatly has to come off as sydhawk has said. Once you get it off it's pretty easy. Just work on both sides of the red "clip" to get it out.
Jeff
