ok for the install I am going to use the relay and the aem to controll the fan... I am told that I need to wire the switched ground wire from the Bosch relay to Pin #55.. so.. does this look right?
Looks good, make sure you are using atleast 10 guage wire from the battery to the relay, from relay to fan, and from fan to ground.
