ok, i cleaned the motor today w/ water/gunk. started it up idled shaky. rev it and it hesitates, but slowly goes up. sometimes it will pop and crackle. then will not hold idle and will die. try to start it back up, and it will take like 5-6 tries.
what can i do, or not do to help this. i scanned for codes and got 16, and 66
this is for my stock 5.0
do you still have the rubber boot on the distributor? you could have gotten water in it. just a thought.
no its not on it, i took it off awhile ago
you porbally got the wires/plugs wet and or any electrical connection..did you do it whiel the car was running?
no, not while the car was running, if i got the plugs/wires wet, what can i do to make it run right?
