1 - 18 of 18 Posts
I went to a local shop to see if it were possible to install some cats onto my '88 Mustang which is equipped with Hedman long tubes and Bassani X-pipe. They said $405 for parts & labor. I asked them how much is labor because I wanted to get some of those Random Technologies cats. They said they only use their own cats. I asked what kind. They said Magnaflow.
So are Magnaflow cats any good? Is $405 worth it for the cats and the installation?
I'm also thinking about installing an electric exhaust cut-out on the collector of the long tubes for "off-road" applications.
well you can get dr gas high flow jobs for like 250 a pair. Add in an hour or 2 labor for the exhaust shop to drop your mid pipe, cut out 2 sections, weld the cats in, and bolt it back up. You are looking close to 350-400 bucks.
A good alternative is to just hold on to your stock h-pipe or pick one up. When inspection time comes around just bolt the stock pipe up and you are set.
The electric cutout may be another option but I honestly hear of only one person out of 100 people that say they are going to do it and actually do.
I don't have to worry about emissions tests. I just want to quiet the car down and reduce the gas smell. The cut-outs will be nice in case an LS1 pulls up beside me.
i dont think an exhaust cut out will make a difference. If you have the power then you have it. If you open up the exhaust when you race the LS1 (and you may lose) then you'll have a slow car with a loud exhaust! heh heh...
Magnaflow converters are made by Car Sound- same company actually-
They ARE the BEST flowing converter on the market hands down.
A Magnaflow converter WILL outflow a Random converter any day.
Converters usually result in a 10hp decrease versus a cat-less pipe. With electric cutouts I may get that 10hp back.
'90 Windveil Blue LX
why not get a bassani x-pipe with cats and save yourself the headache???
my combo consists of a stock 302 shortblock, which i freshened up few years ago, track heat heads, rpm intake, f-cam, bassani longtubes (158-134), bassani 2.5" x-pipe with cats and mac cat-back, f-cam, 1.6rr, 75bullet, 24#, 373, no porting, stock compression and all smog s**t. with these mods the car made 316rwhp and 322rwtq.
i then installed a bassani orxp cause i got a killer deal on it. the car sounds insane and since i've had some free time on my hands lately, i decided to go the dyno. the car made 319rwhp and 323rwtq, which is not much of a gain. roughly 3rwhp across the board. the interesting thing is that i had a pretty big drop in power between 3200-3800 and with the orxp that big dip is gone. i'm pretty sure that bassani uses random converters, which obviously flow really well.
Because I have long-tube headers.
i know you have longtubes (i can read).
you are running a bassani orxp so why wouldn't a bassani high flow cat x-pipe work?
I had to replace the cats on my BBK H-pipe... cause I hit a speed bump a little too fast.... I paid $110 each installed for the 2-1/2" carsound highflow cats... so that brought me up to $220 for both... The box said makers of Magnaflow... from my understanding.. the Magna flows come with a stainless polished heat shields... and the carsound ones have stainless construction with aluminized steel heat sheilds... its your choice.. but expect to pay more for the Magnaflows....
Actually Bassani does not use Random converters....
so what do they use?
Discussion Starter #14
Re: Re: Magnaflow cats $405 installed
I supposed it would work just fine. But I didn't know they had a short x-pipe with cats.
Re: Re: Re: Magnaflow cats $405 installed
did you read any of my replies?
"bassani longtubes (158-134) and bassani 2.5" x-pipe with cats"
i got mine from fairway ford in cali. great place. i think i paid like $400 or $425.
Discussion Starter #16
Re: Re: Re: Re: Magnaflow cats $405 installed
Yes. But I diodn't know that before your reply.
Anyway, the short X-pipe wouldn't fit with my headers. They took a full-length off-raod X-pipe and cut it in order to install it. So I may be better off having these cats installed in my current X-pipe.
Thanks for your help.
what he is trying to say is bassani makes a matching x-pipe w/ cats to fit their bassani long tub headers. even though your old x-pipe was hacked, the new one will still fit.
Discussion Starter #18
Well, I had the cats installed. Didn't quiet it down much, but at least the smell of gas in the exhaust is gone.
1 - 18 of 18 Posts
