i think i have some of the harnesses still also but not sure? will have to dig for em but the amps are out of 98gt and worked when pulled. make reasonable offer and theyre pretty much yours
sorry, havent been on in a while. they were from my friends totaled 98'. i bought the whole setup but i have an aftermarket head unit and amp so i only used the rear box with an additional amp that i had. saved me some time in wiring since my car didnt originally have a mach system. i used everything but the 460 amps and have no use for them. i think i have some harnesses for them as well but not sure if i still do or not? if your car is a 460 car then its a direct swap in but if i have the harnesses which i believe i do, then they will be included as well or you can find them very easily from a donor car or on here.
Discussion Starter · #4 ·
25 shipped! some one must need these?
Discussion Starter · #5 ·
ttt...rear mach amps, both sides
