Look no further. For sale 6.0 with wire harness and computer ported z06 heads harden push rods and double valve springs titanium locks and retainers.fresh 3 angle valve job, heads professionally set up shimed springs for correct seat pressure not just thrown in. Vic jr intake manifold. Demon 850 carb. Arp head studs and rod bolts. New water pump. Billet timing chain and gear. Comp 600 lift cam. This thing flat out screams. Very drivable makes good vac for brakes as well. Comes with headers for swap
(Also have complete computer and harness for efi)
C4 Trans built billet input shaft. Rollrized upgraded sungear. Reverse man vb. chromemoly driveshaft 1350 spicer ends. Billet converter and bellhousing made to bolt to lsx motor. Deep aluminum oil pan
Has tubular front suspension and rear suspension with aftermarket k member built 8.8 5 lug swapped front and rear. Sn95 front brakes
630-581-8790
630-581-8790
