1 - 20 of 21 Posts
alright so today i went out to run a few errands and got done and took my car to a car wash and got done and on the way from driving home, my car started making this weird shrieking noise each time i pushed my clutch in. the car sounded fine after i put it in gear and drove but each time i pushed the clutch in, it would make this noise (like nails on a chalkboard). is it time for a new clutch? HELPPP
yep sound like throwout bearing dry and spinning on the bearing retainer. do you still have the stock retainer on trans if so it would be best to replace it with a retainer
Discussion Starter · #5 ·
how much should that cost at a shop? im living on campus and can't really do it myself.. should i just go ahead and replace my clutch too? its been 80k miles on the stock clutch
When a TOB goes bad, does it only make noise when pushing the clutch pedal, or also when the car is in motion?
Dan, the stock clutch should last you at least 140,000 miles unless you abuse it.
For a temporary fix that has been working in my car for months, take the clutch fork cover off the side of the transmission. I believe it is only one sheet metal screw holding it on. Spray a good quality lubricant oil like number 5 or possibly wd40 on the throwout bearing. Should quiet it down immediately.
my bad i forgot what forum i was in .
as far as replacing the clutch it just me i would if going thur the trouble of replacing throwout bearing
the cost could range any where from 150 up plus cost of the clutch maybe able to find someone to do it on the side alot cheaper if you help
try your local auto part store you may find someone at the counter or get you a contact of someone
TOB for sure, same thing with my brothers cobra.
throw out bearing.
I think these guys have nailed it. Throughout bearing gets my vote as well.:king:
Now, sit down and get prepared for some major cash outlay.
You are an idiot if you just have the bearing replaced! This requires dropping the transmission!...which requires dropping the exhaust!
Compound that labor and the replacement exhaust that may or may not be required and then add the cost of a complete clutch assembly that should include a resurfaced flywheel.
This is easily going to cost you $1000.:shakehead
I told you to sit down...:blam:
whata heck is that noise trevor?
Nope, not ticking. Notice how it stops when I put my foot on the clutch. Even if it were ticking, I think it runs pretty well from the times I have gotten out of it.
1 - 20 of 21 Posts
