What should I check. Where can I get a new CCRm. How much are they. I guess I didnt phase my eec, as the car still runs and idles fine.
Let me know
Gary
Not sure about how to test but, you have to get a new ccrm from ford dealers, they cost around 175-$200. Anyway its a ttt
In looking back. I dont see anyway I could have touched a 12 volt to it, because the wire wasnt even stripped that I was working on. I have been having intermittent ac problems also, so maybe the CCRM is just bad. If so, why does my fuel pump still work ok.
Also, can i just remove the CCRM and have someone check it?
Will my code scanner help me?
Gary
Hi there,
Preform a self-test and at the beginning of the self test the low speed fan should come on, then the fuel pump, then the high speed fan should come on. If the fans don't come on you may need a new fan. As long as you hear the clicking sound of the relay the CCRM module should be fine.
See ya. Michael Plummer
