1 - 8 of 8 Posts
Well I'm in the market for some e.t streets and some 15" weld rims for the rear......what size of tires do you guys run. I'm sc'ed and 3:73's. Where is a good place to order the tires and rims from?
I had a 35th last year and I ran on some 26X11.5 et streets. My mods were a 4.10 gear, longtube headers, k&n and it went a 13.15 @ 101.78 with a 1.78 60'. I was comming out easy so I wouldnt brake an axle.
must be more of you who can help me out here
A 15x8 (5.5" BS) or 15x10 (6.5" BS) would work well. I'd also go with a 26x11.50 ET Street on either rim size. If you are worried about too much traction go with the narrower rim and a set of 26x10.50's.
If I were you I would go with a 15x10 wheel and a 26x11.5 ET street. I have 15x8's with a 26x10.5 ET street on my N/A auto and it struggles for traction at times depending on track prep so the extra width can only help you.
I don't see anything in your mods with 31 splines or a aftermarket posi/ You'll breaky that rear if you don't upgrade.
Josh
It seems liek your either lucky or your not for how long stuff lasts....yes I know I may break something in my rearend but then you have guys who have been launching on slicks for a long time and don't break anything at all........if it breaks replace it with something stronger is my motto
1 - 8 of 8 Posts
