I have a 430 Windsor being built and it will be a pretty serious street engine. I'm considering doing EFI but there are not many tuners in my area (Sacramento) who tune Holley EFI. Does anyone know of a good calibrator who can tune this combination mentioned below?? It will be street/strip driven:
68 Falcon
Powertrain:
TKO 600 5 spd - converting to a T-56 Magnum Mcleod RXT Twin-disc clutch
9 inch rear 3.70 gear ratio 31 spline Datona bearing True-Trac posi
Enigine specs are as follows:
430 Windsor Specs:
Short block*
68 Falcon
Powertrain:
430 Windsor Specs:
Short block*
- Dart Iron Eagle Block 9.5 Deck 55mm roller cam core .904 lifter bores
- Lunati Signature Series crank
- Oliver billet I-beam rods (Speedway Series/H13 tool steel pins)
- Diamond Racing pistons – TFS Dome/Job changes
- Total Seal ring set
- King XP rod & main bearing
- Trick Flow Specialties Twisted Wedge R from Total Engine Airflow (356 CFM @700 lift intake - 282 @700 lift exhaust) 2.08/1.6 valve diameter.
- Victory 1 Titanium intake valves – 95 grams Ferrea stainless steel exhaust valves
- PAC 1224-16 springs
- T&D shaft rockers – ISKY EZ Roll Max .904 bushed lifters
- LSM custom cam 55 mm 744/742 lift duration @ 0.50 282/296
- Super Victor hand ported intake manifold
- Holley XP 950 cfm E85 carburetor
- 13:1 compression ratio
- Cometic MLS head gaskets
- ARP Pro Series Head Studs 12-point
