How does it differ from a standard spring shock/strut set up ...
I have an idea, but I have never seen one.
What are the real advantages ?
Thanks !!
A picture is worth...
The advantages are:
1. The ride hieght and corner weights are easily adjusted by screwing the colar up and down the threaded body of the shock
2. The spring is considerably lighter then a conventional spring
3. The load is removed from the control arm so a lighter part can be used and the bushings are able to articulate easier.
97 .. You are right ..... a thousand words ..... Thanks !
