I'm getting used to the longtubes and man I really like them - once the car is warmed up. The first few minutes starting cold are not good though - bucking and stalling have become common. Not a big deal really - just a nuisance requiring some pedal play to keep running for the first several minutes.
My question: Do longtubes cause a lean or rich condition and what has everyone done to correct this? I'm thinking I'll need to get a custom chip to address this. Anyone recommend a good mail order chip maker who has dealt with this before?
I'll probably wait until after I get 4:10's installed and get the speedo cal done at the same time. Can I also just skip the T/A and get my timing advance addressed with the chip - or would I be better off having the flexibility provided by the T/A?
I'm curious to hear what others have done.
Thanks,
Dan
Longtubes will make you run lean.
You can get a good mail order chip or use the MAFterburner.To make up the fuel.I get the same bucking\surge until i retuned my fuel.I was running 20% to lean on my long term fuel trim even at cruise.
Makes all the difference in the world.
My car seems to be runnin really lean on the longtubes. I was told that the computer would learn the longtubes but its not happening. Im getting a custom tune quick. I fried the crap out of the plugs on the 125 shot.
my car is running fine with the LT's pulled the plugs after 500 and 1500 miles looked like new, but I have heard several people say that they have had white plugs (lean) after the install maybe I got lucky. I used Fordchip.com for mine and they changed the A/F and timing for me I will still get the T/A later so I can fine tune and they compensated for the gears also the chip is not in yet gears are being installed Monday will let you know how it is
