Long Tubes with a T-56?
Ok guys, I have decided to take the leap and get Longtubes (if possible). I had to get a custom H-pipe for my car with the shorties, so it wasn't dragging on the ground over any bumps when I installed the T-56.
I was wondering if anyone has installed Longtubes with this tranny, and if they have, could they bolt on a Shorty-H or did they have to have it custom made? Which brand did you use (headers and shorty pipe)?
So there may be a custom 2.5" H-pipe available for your T-56 install. ;)
Fill me in guys!!!
PMS Tuning Forum Moderator
Maybe I am misunderstanding you, but you can't use a h-pipe for shorty headers with long tubes. Anyways, if your not running catalytic converters then you should be fine. On my buddies 89 he runs BBK long tubes/BBK off-road h-pipe with no problems with the T-56. I will be installing a T-56 in about a month, and I will, probably, have to modify my h-pipe so I can move the catalytic converters back some to clear the transmission.
Troy
My father has a "shorty" h-pipe on his car with long tube headers, so I know it is possible, just not sure with a T-56....
Anybody????
I talked to D&D and they said some cutomers have done it, but not others, but most have clearance issues if they do not get a custom pipe......
More money to spend.....bummer
Actually it wont be bad at all. Just order the headers and have a custom H-pipe made. Thats what I did and it only cost $50 and was better fitting than the POS BBK short h-pipe.
