I guess I'm hoping those that have built one will chime in. I'll try to build it regardless.
I think the other fellow was correct. I'm open to anyone correcting my reasoning, but it seems to me the change would have to significantly impact angle to have any noticeable effect. The 351W rod is already long compared to stroke.
At half stroke I calculate a stock 351W rod to be at 82.36 degrees.
At half stroke, a 351M rod will be at 81 degrees.
The force at 81 degrees is 1.012 times the force at 90 for an infinitely long rod.
The force at 82.36 degrees is 1.009 times the force at 90 degrees for an infinitely long rod.
Dwell time changes at or near TDC are even less.
With the 1/2 inch longer rod you reduced force caused by angle by less than 0.3 % at half stroke, and reduced it much less when closer to TDC or BDC.
Since angles are a sin (sine) function, the change doesn't get large until the angle approaches 60 degrees.
sin 90= 1
sin 80 = .9848
sin 70= .939
sin 60 = .866
sin 50 = .766
sin 40 = .643
1/.643 = 1.56 times the initial load.
This works with rope tension also. If you look at the beta column in the link below, an infinite rod length would be 90 degrees. Both of your rods are around 80 degrees. It would be more important to get a stronger rod than a longer rod.
Tension Increase in Ropes due to Angle
