Ok, I've heard a few different stories about the location of the turn signal flasher. I'm afraid mine is toast...when move the multifunction switch to activate the signal no lights come on. My 4 ways work, but thats a seperate circuit.
So, I know a lot of you have ripped the dash's apart. Where is that little turn signal blinker located? I cant find it through all the alarm wires and braces under there...
Ford says "Behind Instrument Panel under instrument cluster".
Look up under the steering column, it's tucked nicely away in there. If it's stock, it'll be baby blue.
looks like i'll be taking the seat out! I cant get my tall a** up under the dash far enough to see whats going on real good...
thanks for the info...
Actually, the manual for my 91' was wrong. It is behind the radio/center section of the dash. Took me awhile to find it since I was looking under the driver's side of the dash.
lol I hear that dude. Last night I crawled under tehre to detach the brake booster lever from teh brake pedal and I think I tore a trap in the process and got my arm stuck up under the dash for 10 minutes... I can only imagine what the neighbors were thinking watching me writhe around trying to get free ... so be careful :D extern double dSimTimeOffset;
void delay (const unsigned int& uiMilliSeconds);
const double getCurrentTime (void);
turn signal flasher
Try going in from the passenger side and look behind the trim next to the radio. That's where I found mine( 90 GT ).
