I replaced my wires & coil packs today with Livewires and Screamin Demon coil packs. My old wires were shot so obviously I noticed a difference right away. I just wanted to say that I'm totally satisfied with the service from Performance Distributors and the quality of their products. The only thing I would recommend is when using their billet wire separators, find yourself 2 stainless bolts that are a bit longer than their wire separator bolts for using the 4-wire separators around the alternator. By doing this I was able to put nuts on the underside and securely mount them to the stock brackets.
Just my .02
Did you pull your plugs and gap them to .065 like it says in their ad?
I was already running the plugs at .065 before I installed their wires & coil packs. It ran just fine with the stock ignition at .065 untill my wires went bad.
