just wanted to know what all was involved, and what is needed for this swapp, any help would be great, thanks for your time.
Jason
Much cheaper and practical just to go with a centrifugal blower.
If you want a roots blower go with the Magnacharger kit, Kenne Bell for the twin screw, or with a P1SC ProCharger for a centri...
Check out http://www.trixters-playground.com/
Check out the boards, they can answer just about any question you have about putting a blower on a F150...
if you want to put a lightning blower on a 5.4 you will need this
Lightning lower intake with the intercooler
The supercharger, and Upper intake
Lower pulley, and a belt
Front bracket and idler pulleys off a lightning
Heat exchanger, heat exchanger resevour, hoses, intercooler fluid pump, and brackets
Lightning oval throttle body
Lightning rubber intake boot, and 80 or 90 MM MAF Meter
A few vacuum lines, gaskets
Larger fuel injectors
A few selinoids, boost bipass actuator That are part of the lightning supercharger setup.
Then someone to tune a chip so it will run propperly
I may have left something out, but those are the main parts needed.
You also have to figure out a relay setup to turn the intercooler pump on when the truck starts, ans figure out how to wire up the selinouds, and stuff.
It is a lot of work, but it can, and has been done.
With all the KB blowers being sold there may be a lot of good used Lightning superchargers for sale soon.
