I called Ford regarding these injectors and the parts guy looked up 42 lb injectors in his computer and he asked me for a calibration number. I told him I wanted the lime green ones but he said he had like 20 different injectors in the computer. Does anyone know the calibration number for these injectors?
Thanks.
If you buy the Ford/Bosch 42 lb injectors from your local Ford parts dept, they will be outrageously expensive. The best deal on injectors is through the FRPP program.
I got mine for $285 shipped from Modern Performance NW (866) 693-4441 (a few months ago).
You can contact BlwnCpe, he has been a member here for years and has started his own business, Sybersport.com
Yep, it is on a 302, the stock 160,xxx mile 302.....
Basically, because I already had it, along with a set of nicely ported GT 40 heads. When I decided to go SC, I had too much compression, so I bought a set of heads that I could slap onto my 408 that is in the works.....
