1 - 20 of 25 Posts
Hey guys/gals, I'm going to crowdsource the next upgrade on my 92 notch. I've never been in these power levels before, so I'm starting to feel a bit lost in terms of supporting mods with my turbo. Here's a list of my current mods, so feel free to recommend what you think I should do next (what would be most beneficial)!
3:73 gears
Weld Draglites with drag radials on back, skinnies up front
340 lph aeromotive fuel pump
60 lb Siemens Deka injectors
Aeromotive Adjustable Fuel Regulator
Aluminum Driveshaft
Spec Stage 2 Clutch
Subframe Connectors
UPR Adjustable Upper and Lower Control Arms
BBK Lowering Springs
Lakewood 50/50 Drag Shocks (stock struts in front)
67mm Ball Bearing On3 Turbo
SVE Aluminum Radiator
Contour Dual Fans
Straight Y-Pipe with Cutout
Flowmaster Mufflers w/ Dumps
Trick Flow Street Heat Upper and Lower Intake
E303 Cam
75mm Throttle Body with EGR Spacer
Ford Racing 9mm Wires
MSD Cap and Rotor
Autolite plugs
GT40 Cast Iron Heads
1.7 Crane Cams Roller Rockers
Holley EFI - Terminator X
Thanks for helping me decide my next mod!
You still rocking the stock fuel lines?
Is the car currently running and driving?
Generally you want to have an objective if you're modifying something unless you're just wanting to spend money for the sake of it.
Get rid of the E cam.
  • Like
Reactions: Ed Curtis
Discussion Starter · #6 ·
Not necessarily spend for the sake of it, but rather take care of some mods that would complement the turbo. The car is up and running, consider it a fun weekend street car.
Old timer
REMOVE AND REPLACE:
E303 Cam
  • Like
Reactions: Whitexc
skinnies up front aint my idea of a fun street car
to each there own i guess
  • Like
Reactions: Whitexc
Straight thru design muffler
dart block
good fan controller if you don't have one already
work on the interior (LED backlight, seats, etc).
1 - 20 of 25 Posts
