Has anyone ever experienced leaking gas out of the tank when on the bottle?? I'm running the NOS 5115 jetted for 100hp with 24 lb injectors, and whenever I hit it I end up leaking gas out of one of the fuel lines.
I took the tank down and it is the line farthest to the front of the car with the little rubber grommet that goes into a hole in the tank. Is this the return line or just a vapor line? It actually seems to be leaking from around the grommet. Any sugestions??
Yea, I'll have to check that out. It looks like it's leaking out of the rubber grommet.
Is this the return line or just the vapor line to the charcoal cannister up front???????????????????????
