1 - 8 of 8 Posts
Anyone know of where I can get a larger diameter crank pulley for Modular motors? I have a 6.5 in on now stock and would like to find a 7-8" crank pulley for added boost without going smaller on the Supercharger...fighting belt slip... I called a few places with no luck...
Thanks for looking
Discussion Starter · #2 ·
Don't the 2nd generation Lightning's run with larger crank pullies?
You could check to see if one of them would work. Just an idea.
Discussion Starter · #6 ·
I never knew the Lightning had a larger crank pullie. I know that the blower pullie thats bolted to is larger. I will have to check into that. Thanks.
Im not sure if the older crannk pullies will work on modular motors.
Discussion Starter · #7 ·
I called asp and they do not have one and will not make one. The dampner is part of the pullie
1 - 8 of 8 Posts
