1 - 8 of 8 Posts
Found a deal on some Lakewoods 90/10s and 50/50 brand new for a fox. I have a 95. Was wondering if I could use these with my Eibach drag springs? Or will they be too short? What about caster/cambers?Thanks!!
Discussion Starter #2
Going to get them and try. But should I try and get front coil overs or try and stick with some front eibach drags?
j-m Cain
If the front has been lowered more than 3/4", they will work. If not, they will be 3/4" too short. Other than the length of the strut, they are identical.
FWIW, I run 4-cyl Fox front springs and the Fox-body 90/10s. The car is lowered approximately 2-2.5" in the front...:)
Good Luck
Thanks thats what I was thinking....but are the caster camber plates needed?
They aren't technically "needed", but they are nice for getting the fron end aligned correctly after lowering.
You can still use the factory c-c plates with the struts, however.
Ok so then if i have an Eibach Launch Kit in my 95', then I would have to replace the springs to the stock or lowering springs in order to fit a 90/10 Lakewood strut in the front.:mad:
No I dont think so...the eibach drag is supposed to lower the front two inches I think...someone please correct me if Im wrong...I need to know too.
1 - 8 of 8 Posts
