Ok, based on a few comments I ordered a set. Now, I assumme you can put them in 1 tube at a time then slip the collector on?? At first thought this sounds much easier than a fixed set of headers.
Thoughts? Installation comments on these anyone?
BTW, I ended up going through RaceParts. Was a cool deal, they are going to install 4 o2 bungs for me also. 2 stock, 2 wideband.
If you are going to plan on installing them with the motor/tranny in the car, plan for a big hassle. If you are running a blowproof bell, that might be an issue, your mounts might be an issue, your steering shaft might be a problem, I assume your starter is small, becuase it will probably have to be. IMHO big headers are easiest to install out of the car. By the way, if you have a ceramic coating on them and want them nice, you will have a hard time keeping them that way when installing with motor in car.
