I was at the track last night and have was logging my runs except the last run wich was my best at 13.523 @ 104.66 with a 60' of 2.117 stock tires (at 34lbs) and suspension. I noticed that on the other runs that in 2nd and 3rd gear over 5500 RPM im showing 1 for knock sensor. Does that mean it detects 1 knock or detects knock in general.
It means you knock sensor has been activated. You probably have pinging situation and have not heard it yet. Or something is mechanically loose ...like loose power steering pump brackets, alternator, etc..this will created a knocking vibration for the sensor to pick up and generated code.
Discussion Starter · #4 ·
Thanks stang 88 I wasnt sure since some of my friends have VR4's Stealth and 3000 GT's and theirs actually count..
guess the timming adjuster is out for me then :(..
or have to get some better gas in there.
