Does anyone know the specs for Bob Kennedy's "Kenne Bell" cam? I am picking out a converter and need the specs for it. Just curious if anyone knew them, if not, I will contact Bob. Thanks
Don, are you posotive that these are the specs? Also did you put yours in top dead, retarded or advanced? Thanks
Discussion Starter · #5 ·
OK thanks Don, just wanted to be sure when I told my tranny shop
Don,
What does the Kennedy cam you mentioned sound like at an idle? Some loping like the TFS Stage 1 or can you even tell it has an aftermarket cam?
Anyone with a sound track of it?
Thanx!
Discussion Starter · #7 ·
The cam sounds really good, not sure what the TFS cam sounds like but you sure can tell that its aftermarket. No sound clip though, sorry. Maybe if it was a couple months ago before I took the motor apart due to a melted piston
