1 - 9 of 9 Posts
Kenne Brown 96-04 GT Panhard Rod (beyond perfect) Added Pix & open to trades
Brand new and custom powder coated black. Never installed. Shock brackets test fitted, but otherwise untouched. New was 400+ and powder coating was another $100. Asking $250+shipping negotiable or trade for performance parts (looking for 350+ lb rear coil over setup, koni yellow rear shocks, aluminum DS, good mufflers, cobra rack, etc...
New Price $200 + Shipping (as low as I can go w/o starting a wife war)
I'll take some tomorrow.
Discussion Starter · #4 ·
Bump
Discussion Starter · #5 ·
Discussion Starter · #6 ·
bump
Why dont you want to put this on your car?
So should bolt up to a '98 vert correct?
Discussion Starter · #8 ·
I was fortunate enough to score a MM PHB for a a ridiculously low price, and I already had a MM TA in the garage that I was going to use with the KB, but given that the two products were designed for each other I'm going with the matching set that all the Auto-x guys recommended.
There's nothing wrong with the KB. In fact I was thing about using the axle brackets with the MM bar as the MM only has 1 bracket on the axle side and the KB has 2, but I'm not a mechanical engineer so I'll stay with 1 product....
I need the garage space guys. It's a fair price.....
Discussion Starter · #9 ·
bump
1 - 9 of 9 Posts
