I've ran into a small problem...I tried to sit my Kenne Bell on to the lower intake but the Flowzilla on the 'charger is hitting the AFPR and not letting it seat in the back(95 GT w/ GT-40 lower). Will I need to just go back to the stock regulator or could I use a 1"spacer? If spacer then it'd be a question if snout would hit/rub on a Cobra R hood or if the belt included would be long enough. Thanks for any help.
I think most people go with the stock fpr. If you do go with the spacer you will also need to make a bracket for the snout.
Thanks, I had forgot about the snout bracket.
Brandon-- you've got mail... Did you ever find that pulley?
Discussion Starter · #6 ·
I didn't find that other pulley. That e-mail helped...then ran into another prob so I mailed you again. Small steps but learning lots.
