1 - 11 of 11 Posts
Getting ready to install and had a few questions...
Do you have yours 'hard wired' or is it set to come on via a hobbs switch? What do you have the dial set at and which pumps do you use?
I'm getting ready to wire this bad lad up but i dont have the instructions (bought used). Can someone scan thier intructions and email them to me ([email protected]) or fax them to me at (5866206078)
Thanks a ton
I wired mine full time (no hobbs switch).
Tom Crews
Discussion Starter · #5 ·
tom what do you have the dial set at? I'm not sure what the dial means...PSI? Volts? im not sure what to set it at.... :)
Well that's determined by your A/F when tuning :) We turned mine to the mid point (straight up) and got a little more out of the fuel system I have but still could only pull to 6,700 rpm (11.6:1 A/F....I wanted to stay under 12.0:1). When I am just driving around I turn it all the way down, if I feel like I'm going to romp it I'll put it back at the midpoint.
Tom Crews
Mine is set at MAX (turned all the way to the right). That's where Lidio said to leave it and that 's what I did..
Discussion Starter · #8 ·
gotcha....im going to hardwire mine...and i guess ill wait for the tuner (lidio or livernois) to set it....
Wild is yours hard wired?
I found that it works better as a boost-a-spark.. Did you get the instructions yet? I think I've got them, and I can scan them for you if needed.
I think it's hard wired but not sure. Lidio set it up and I never asked him other he told me to leave it on MAX on the dial. You can ask him if you decide to use his shop..
Discussion Starter · #11 ·
Re: Re: Kenne Bell Boost-A-Pump Users Inside Please
David,
I still need them and would greatly appreciate you sending them!!
[email protected]
thanks
1 - 11 of 11 Posts
