I think it still has a bypass even if you don't get the Flowzilla, it's that long tube thing. I'm assume you can get one for a stock lower also, seeing as how the manifolds are the same.
Great to meet you and your wife in person. I did forget one thing, I had a book to give you-"Don's KB Secrets Revealed" but I forgot to give it to you... next time...
Don
Educated guess
Hey Gary,
Haven't purchased a Blowzilla so I guess I could be wrong, but my understanding is that the flowzilla intake is not included. Good news is that, yes, there is a bypass. It is the bypass that comes out on the driver's side and runs accross the front of the blower into the intake on the passenger side.
Let's see if we can get a consensous from the the others.
Don- Its probably for the best. I would have gotten a hernia trying to carry it to the car. Yall come see us again.
Gary
When I ordered my blowzilla it came with the regular manifolds (stock HO LOwer) and the bypass as stated. You could option for the gt-40 manifold as well. You can also upgrade to the flowzilla wich can only be used with the gt40 lower as far as I know.
Hope this helps.
You can get it with the Flowzilla but only with GT40 lower. My friend just ordered a Blowzilla to replace his 1500 and since we are using a Holley Systemax I lower we couldn't opt for the Flowzilla.
CFM - My friends car dynoed 346HP and 384 ft. lbs. last year with his 1500, VERY close to your #'s. Thats was with 7psi and only 8* timing. Edelbrock 6037's, 1.7's,Holley lower, 42lbers, KB chip, LMAF (1st one to use with KB chip), etc. I ran it with 12* timing and 11psi and got a [email protected] with slicks last summer with a dying clutch. I'm sure you be WELL in the 12's!:lol: FYI..with an all stock motor and just exhaust and SC it ran a [email protected] with a shot traction lok...
Pardon the CAPS, but I cut and pasted right from KB's price list-here are all the options....
MUSTANG / T-BIRD 4.6, 5.0 (1500) 1.5L
* TS1000 KIT 75 2899.00 6 PSI KIT W/AC ('89-'93 MUSTANG 5.0)
* TS1000-C KIT 75 2899.00 6 PSI KIT W/AC-GT40 LOWER ('93 COBRA 5.0)
* TS1000-GT KIT 75 2899.00 6 PSI KIT W/AC W/GT40 LOWER ('89-'93 MUSTANG 5.0)
* TS1000-S KIT 75 2899.00 6 PSI KIT W/AC SPEED DENSITY ('86-'88 MUSTANG 5.0)
* TS1000-GT KIT 75 2899.00 6 PSI KIT W/AC - W/GT40 LOWER ('86-'93 MUSTANG 5.0)
* TS1000-GTS KIT 75 2899.00 6 PSI KIT W/AC - SPEED DENSITY-W/GT40 LOWER ('86-'88 MUSTANG 5.0)
* TS1000-94 KIT 75 2899.00 6 PSI KIT W/AC ('94-'95 MUSTANG 5.0)
* TS1000-94C KIT 75 2899.00 6 PSI KIT W/AC-GT40 LOWER ('94-'94 COBRA 5.0)
* TS1000-T KIT 75 3099.00 6 PSI KIT W/AC ('89-'93 T-BIRD 5.0) NOTE: REQUIRES FIBERGLASS HOOD W/ SCOOP TO CLEAR SUPERCHARGER
* TS1000-96C KIT 75 3599.00 6 PSI KIT W/AC ('96-'98 4.6 COBRA 4 VALVE) INCLUDES BOOST-A-PUMP, HI SPEED FAN KIT & MONO CHIP (UP TO 15 PSI)
** TS1000-99 KIT 75 3699.00 6-16 PSI KIT W/AC ('96 UP 4.6 MUSTANG 2V) NON INTERCOOLED INCLUDES BOOST-A-PUMP, SWITCH CHIP
* TS1000-03C KIT 75 3699.00 6-20 PSI UPGRADE KIT ('03 UP COBRA) INCLUDES SWITCH CHIP & BOOST-A-PUMP (ADDITIONAL PULLEYS $69 EACH)
MUSTANG 5.0 BLOWZILLA / STANDARD INLET WITH BILLET BYPASS VALVE (2200) 2.2L
* TB1000-BK KIT 75 3299.00 BLOWZILLA 8-18 PSI KIT W/AC ('86-'93 MUSTANG 5.0) (SPECIFY BOOST)
* TB1000-BKGT KIT 75 3299.00 BLOWZILLA 8-18 PSI KIT W/AC-GT40 LOWER ('86-'93 MUSTANG 5.0) (SPECIFY BOOST)
* TB1000-94-BK KIT 75 3299.00 BLOWZILLA 8-18 PSI KIT ('94-'95 MUSTANG 5.0) (SPECIFY BOOST)
* TB1000-94C-BK KIT 75 3299.00 BLOWZILLA 8-18 PSI KIT W/AC-GT40 LOWER ('94-'95 COBRA 5.0) (SPECIFY BOOST)
MUSTANG 5.0 BLOWZILLA/FLOWZILLA INLET WITH BILLET BYPASS VALVE (2200) 2.2L
* TB1000-FB KIT 75 3599.00 BLOWZILLA/FLOWZILLA 8-18 PSI KIT W/AC-GT40 LOWER ('86-'93 MUSTANG 5.0) (SPECIFY BOOST)
* TB1000-94-FB KIT 75 3599.00 BLOWZILLA/FLOWZILLA 8-18 PSI KIT W/AC-GT40 LOWER ('94-'95 MUSTANG 5.0) (SPECIFY BOOST)
