Peter92lx,Well the day finally came to fire up the car. Everything went fine considering I also did some major changes to the oil cooling system and added an Accusump to the car. I did run into one problem with the wideband controller. I'm running the innovate DLG-1 in my car which I installed around 3 years ago. When I made the changes to the Analog output it's supposed to sync the DLG-1 settings with the LC-2 but it wasn't so I got a DTC error code. I had to disconnect the LC-2 from the DLG-1 plug it directly into my laptop and programed it. Then the DTC went away. I did find the timing was off so I got that set. The rest of the setup went fine. I still need to take the car on a test drive to see how it runs.
The one thing I did notice is the factory temp gauge is reading really high. When I look at the temp on the Pro-M it's reading normal around 190 but the gauge in the car is reading a notch above the halfway. If I look at my autometer gauge its reading about 193. Normally before the Pro-M system the car would stay around middle of the gauge when sitting idling. I'm guessing the Pro-M is reading the same sensor as the temp gauge.
The Pro-M EFI reads temperature (for ECM) from the ECT sensor in the heater tube located near the thermostat housing (passenger side). The dash temp gauge reads from the sensor located on the driver's side front of the lower intake manifold. The ECT sensor in the heater tube is the one that matters the most.
V/r, Jim T
